Subject: Re: Manually applying PVC edge banding
9/21/20
We have an odd situation where we need to apply some 1 3/4" .018" PVC banding to some parts we cant run through the bander. Running a few test with contact the adhesion is not great at all. You can peel the banding off with moderate force and while the contact stays on the banding a bit it peels off consistently to where the back of the banding is just as clean as it was off the roll. Banding supplier doesnt have much to add stating that contact should be fine. Wondering if anyone has any input. All the standards, even application both surfaces, plenty of dry time (to the touch), warm, new material.
9/21/20       #2: Manually applying PVC edge banding ...
TonyF
Mark B:
I'm guessing that you can't use the bander either because the piece is too big or the edges are not straight, or have some kind of angle.
You don't say how much of this you have to do, but what you might try is to have one person put down a bead of hot melt glue (craft store type) ahead of another person who follows with the edgebanding and a roller. It would be tedious (and messy), and might take some trial and error to get the right pace, but it might work.
They used to sell a pvc banding that had double-sided tape applied to it, and you peeled off the barrier paper as you rolled the edging onto your piece. I wonder if a strong double-sided tape like was on that banding might not work in your situation.
Hope this helps.
TonyF
9/21/20       #3: Manually applying PVC edge banding ...
Thanks Tony,
And yes to the bander issues with these parts.
Hadnt considered a hot glue option but without trying it it sounds like something that would be pretty iffy and most definitely messy as you say.
Doing a bit of head scratching as we've rarely had to contact PVC before and never an issue. Never thought it would be a problem and even calling banding supplier they say "its done every day" and dont know what the issue would be.
We could have brought this banding in peel and stick, which in hindsight may have been a better option, but Ive used peel and stick many times as well as Fastcap's fastedge tape or whatever its called and Ive never been impressed which was why opted to just lock it down with contact.
9/21/20       #4: Manually applying PVC edge banding ...
Brian Clancy
Website: http://clancywoodworking.com
Mark
we use a hand held glue pot for curved or radius surfaces by Virutex. Works great.
https://www.virutextools.com/hot-melt-portable-edgebander-peb250-pid291
9/21/20       #5: Manually applying PVC edge banding ...
Thanks Brian,
The angles on these were the reason didnt use a contour bander.
9/21/20       #6: Manually applying PVC edge banding ...
TonyF
Mark B:
Don't know if you are using water-based contact cement; if so, you might try the solvent based instead. If the glue pulls off of the substrate, you might try double-coating that. Perhaps aggressively sanding the back of the pvc edging before gluing might help as well.
Sorry if I have stated the obvious, but I know I have been in situations where the obvious sometimes gets overlooked.
Good luck.
TonyF
9/21/20       #7: Manually applying PVC edge banding ...
Tony, stating the obvious to me is perfectly fine. Im thankful for your input.
No water-based. All solvent.
Substrate seems to be fine. Banding so so. Supplier stated to not in any way sand or abrade the banding that its primed. In tests we cut one back hard and cpntact anyway, not much better. We wouldn't deviate from manufacturer spec regardless.
9/22/20       #8: Manually applying PVC edge banding ...
james e mcgrew  Member
use a laminate or phenolic paper first then apply the PVC with contact
9/22/20       #9: Manually applying PVC edge banding ...
Tom Gafgen
Two thoughts , try a very light first coat on the banding with a very long dry time before a not too heavy second coat to re activate it and or maybe try some other brands of glue .
9/22/20       #10: Manually applying PVC edge banding ...
Jack Mazzuchelli  Member
https://edgecoinc.com/peel-stick-edge-banding-pvc-wood-veneer/. They have this in all brands,matching mica, wood u stain etc
9/22/20       #11: Manually applying PVC edge banding ...
Al
Years ago I did laminate doors that had a cove finger pull. I would put masking tape on the edge of particle board then run it through edgebander. The glue did not stick very well to the masking tape but adhered to the pvc banding. I would just peel the banding from the board and then heat gun it to the cove on the door. Some masking tapes work better for this than others. Maybe this would work for you.
9/23/20       #12: Manually applying PVC edge banding ...
Tom,
Thanks, Thats pretty much what we had wound up doing. Doubling up helped. We also switched to a steel roller instead of rubber. Bigger job I'd ditch our old contour bander and buy a new one that would run angles.
Jack,
Appreciate the tips. We have run EdgeCo's peel and stick as well as Fastcap in a couple situations and Ive just never been impressed with the bond which is why we opted for contact. Even at the bond that caused me to post, the contact was tougher than any peel and stick we've used but keep it in my for sure.
9/23/20       #13: Manually applying PVC edge banding ...
Al,
Thats a pretty impressive tip/trick that I will definitely keep in mind. Not sure it would have worked on these lengths but man that would sure be handy in some spots to be able to use the bander as a hot melt applicator. Im going to give it a try just for fun on some test pieces. Seems like it may be tricky to get enough heat for the bander glue but not foul the PVC.
Great tip.
    • Limtech Industries, Inc.
    • CP Adhesives
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • Wood Doctor's Rx, LLC
