Subject: Re: Drola hinge
Drola hinge
1/29/23
DTD Member
Trying to fix a cabinet we bought new with Drola Muvon hinges. The hinges were not installed properly or fell apart in shipping from overseas to the US. Need a guide on how to install and/or adjust the Drola Muvon hinges.
1/30/23       #2: Drola hinge ...
No surprise. These come from Indonesia and are likely made in China. They do not know the meaning of warranty or even replacements.
If you can send me a photo of the hinge, from a couple of different angles, I may have a solution using a similar hinge from a reputable manufacture with easy access here in the U.S.A. Here is a link to their web page.
Dennis@saliceamerica.com
Best of Luck
Dennis Bean
Drola Muvon Hinges
1/30/23       #3: Drola hinge ...
1/30/23       #4: Drola hinge ...
DTD Member
Unsure what the two screws are for? Just to lock it in place after being snapped in? Why then is one screw in a slotted piece?
View higher quality, full size image (1920 X 2560)
1/31/23       #5: Drola hinge ...
Hello DTD,
Is the door of this cabinet at a 45 degree angle as for a cabinet that is meant to be in the corner of the room? The shape of the hinge leads me to think this.
Dennis
2/4/23       #6: Drola hinge ...
DTD Member
I do not think the cabinet was made to be in a corner. We have it against a wall but not in a corner. The screw towards the inside of the cabinet looks like a regular screw that goes through something slotted. The screw towards the outside of the cabinet looks more like an Allen head screw in that the head of the screw can go below the surface of what it's screwed into.
2/4/23       #7: Drola hinge ...
Hey DTD,
Sorry to play fifty questions but your photos appear that this is an angle hinge of some sort (Maybe -45 or -30 degree). Is your cabinet shaped, more or less, like sketch A or B?
Dennis
View higher quality, full size image (585 X 467)
2/4/23       #8: Drola hinge ...
Like A or B
View higher quality, full size image (865 X 592)
    • Limtech Industries, Inc.
    • Denray Machine
    • Cabinet Pro
    • Impact Search and Placement
    • RT Machine Co.
