Subject: Re: I need advice !
I need advice !
1/6/24
Jon Member
I wanted to see if anyone has an edgebander from tool tech and if so how you like it? I have contacted them about the 700 and wanted to get some of your opinions…I am a one man shop and I primarily build frameless cabinets. I had a Cehisa EP7 and had a lot of issues with it, I have since sold it and have been ironing on for several months….im getting a bander just trying to get the best for me! thanks in advance
1/6/24       #2: I need advice ! ...
Kurt. Member
Hi Jon. I can relate with running a small shop. I however purchased a Cehisa EP8 to abandon pre glue EB, and aside from some cleaning and new parts (and forum reading) its been a pretty good little machine. Huge time saver. What issues were you having? Tool tec doesn't appear to be as robust as what you had, but for one man shop may be fine. Im sure someone will be more helpful than me….. i also would have loved to have a premill, it doesn't look like its an option on the 700.
Good luck.
Kurt.
1/7/24       #3: I need advice ! ...
Quicktrim
Look for a used holzher machine.
Pretty bullet proof and older ones usually go for a few thousand dollars.
I have a 2001 triathalon 420 with everything but premill still running great.
Will be upgrading soon , I would let it go for a few thousand , in Denver metro area.
1/7/24       #4: I need advice ! ...
Jim Herron
I'll second the Holzher recommendation, without PLC
When the PLC goes out you have an expensive brick
The analog keeps going with minimal upkeep
I have a HH 1435SE I bought used after owning a Cehisa as well
I got so tired of disassembling and cleaning the glue pot
I'll buy another if I find a clean low hours one available
1/8/24       #5: I need advice ! ...
Quicktrim
Like Jim , I ran a 1997 1435SE before the 420, great little machine ,look for one on the web , while they are asking way too much on some if you offer a couple grand they will take it as used banders over 15 years old are pretty much worth little over scrap metal .
