Troubleshooting SCM Edgebander
4/7/18
Armando
Hi Guys,
I have an edgebander
SCM Basic 2 and
Is not heating-up
Temperature stays low.
Thanks...Armando
4/8/18       #2: Troubleshooting SCM Edgebander ...
Dan cook
Sounds like you need a heat station rebuild. You might check underneath in control panel to see if any breakers are tripped.
4/9/18       #3: Troubleshooting SCM Edgebander ...
Rob Young  Member
Website: http://www.cmsrepair.com
Check for a tripped out breaker as Dan suggested. The problem could also be the temperature controller and contacts not closing on it to call for heat. I believe they used Gefran on that model. The problem could also be the contactor that passes the voltage to the heating elements. The heating elements could also be bad but I would doubt all of them are bad so I would suspect it would simply heat up slow if it were a heating element issue.
9/17/20       #6: Troubleshooting SCM Edgebander ...
Robert E Haupt
Have scm edgebander that when using white melamine tape put small teeth like pressure marks in tape after running thru. Any ideas why?
10/26/21       #8: Troubleshooting SCM Edgebander ...
Doug Forester
Website: http://foresterconstructiongroup.com
My SCM edgebanders first trimmer won't return home for the next operation. It will work only on the first piece edgebanded.
Thanks everyone
9/22/22       #12: Troubleshooting SCM Edgebander ...
Bernard
Website: http://mastermillworks.com
I have an scm stefani md edgebander and it is throwing a code 1022 roller conveyor position of joke is not compatible with the stored position!! What's wrong?
9/22/22       #13: Troubleshooting SCM Edgebander ...
Bernard
View higher quality, full size image (4032 X 1816)
2/1/23       #15: Troubleshooting SCM Edgebander ...
Brandon
Hi I have a K230 edgebander and our set temp is 190 and pot is gettting hot but the actual temp is reading zero. Any ideas why the temp isnt climbing?
10/5/23       #18: Troubleshooting SCM Edgebander ...
Mark Armstong
Hi all, we have a SCM ME35 edgebander, it regularly shuts down with the alarm code AL09, We isolate it blow it out to clean it with the compressor and leave it off for a while, it can take up to 30 mins before it will come back on.
What could be causing this and how can i prevent it happening, Thanks.
    • Wood Doctor's Rx, LLC
    • Template Services
    • ECabinet Systems
    • Denray Machine
