Frameless cabinets going up to a soffit or ceiling
9/7/19
Rob Member
Hey guys I was wondering how to deal with your frameless cabinets going up to a ceiling or a soffit. No soffits or ceilings are ever straight so I want a way to install and give a nice look as much as possible. Pics would be great too thanks in advance.
9/7/19       #2: Frameless cabinets going up to a so ...
A scribe piece is put above the cabinets to the ceiling.
Measure the distance every few foot or so and put a line on your scribe piece and cut the piece on your portable table saw.
Then screw it into place from inside the cabinets.
Then caulk at the ceiling.
Some guys put 2 grooves in the scribe piece. This way put the scribe piece in front of the top of the cabinet.
Put a spline in the groove that is closer to the top edge. They then scribe a line with a scribe.
They then put the scribe piece up with the spline in the other groove.
This is the Cadillac way to do it but the reality is that no one can see the scribe line anyway so IMO it is a waste of time.
Does this make sense?
9/8/19       #3: Frameless cabinets going up to a so ...
Rob Member
Hey pat thanks for the response I think i understand what your saying by any chance would you happen to have any pics? Thanks
9/8/19       #4: Frameless cabinets going up to a so ...
Tom c
Pics of Frameless Kitchens to ceiling.
That's all we have been doing the last 30 years.
Our Doors are a 1/4" shorter than the cabinet on top, Soffit board, usually 4-6" high, does not go to the ceiling. Enough for the crown to catch.A strip is pocket screwed behind the soffit,screwed up to from inside the cabinet-NO Face nailing. Pin-tape mitres.
Ones like the hood are done in the shop before hand. Crown -I push for painted on site by others when I can. Sometimes a bunch of planing on the crown is a given.
I do the VIF with a laser and check when I see something wacked..Most houses pretty good . Old Plaster ceilings -Double check and Uncharge ++$$
View higher quality, full size image (752 X 423)
9/8/19       #5: Frameless cabinets going up to a so ...
Rob Member
Thanks Tom for the pics that is some great work, what is pin-tape mitre mean?
9/8/19       #6: Frameless cabinets going up to a so ...
Tom c
Pin Nailer ...
Re read -I missed writing that the soffit board overlays the top of the cabinet 1/8" -
So I get a 1/8" Door gap to soffit.
Profile on soffit edge is same as doors.
Most of the time ...
Another Pic..
View higher quality, full size image (512 X 384)
9/8/19       #7: Frameless cabinets going up to a so ...
Rob Member
Thanks Pat and Tom for the great advice and beautiful work.
9/9/19       #8: Frameless cabinets going up to a so ...
Eddie
We make a "L" shape fascia, install flush with the door and scribe to the ceiling, the last kitchen we did, the designer wants the fascia set back the thickness of the doors (flush with the box), follow pic.
9/10/19       #9: Frameless cabinets going up to a so ...
Rob Member
Looks great Eddie I am assuming that you put the l shape fascia up after you hand the cabinets and screw from the inside of the box.
9/10/19       #10: Frameless cabinets going up to a so ...
Eddie
that's correct Rob, and always making the pieces with scribe.
5/8/20       #11: Frameless cabinets going up to a so ...
Al Gerhart Member
The easiest and quickest way is to make your crown on crown caps, pre made frames that you make out of 4" wide stock to install the crown molding on. Leave the top of the molding a couple inches short of the ceiling. Next, make another crown cap for a 2.5" tall soffit that sits between the cabinet and the crown. Pre finish everything.
Install your uppers. Set the pre made crown caps with the crown already installed and pre finished. Measure every 12" and transfer that mark onto the pre made and pre finished soffit and trim it down. Slip the soffit under the crown and caulk the any gaps between the soffit and crown cap. Only issues if you have a severe sag in the ceiling but usually you can slip in the soffit from the side. Last resort, lower the uppers using the cabinet hangers and crank them back up when you are done.
    • Sandman Products
    • Template Services
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • Better Vacuum Cups, Inc.
    • RT Machine Co.
    • Wood Doctor's Rx, LLC
    • Laguna Tools
