Grizzly 3100Z Twin Drum Sander Belt Tracking Problems
10/24/19
Carl Member
If I am posting in the wrong place please let me know. I have a new to me Grizzly 3100Z twin drum sander. I find it is impossible to get the feed belt to track to the right. I have replaced both the idler and drive rollers, bushings, and aluminum tension blocks, I have tightened and loosened everything 20 times (literally). I have swapped end for end both the drive and idler rollers. The only way I can get it to track is to have all the tension bolts finger tight, as soon as I tighten anything it tracks to the left facing the machine. Has anyone else had this problem? Thanks in advance for any help.
10/24/19       #2: Grizzly 3100Z Twin Drum Sander Belt ...
Carl Member
Sorry should have been 1066Z sander
10/27/19       #4: Grizzly 3100Z Twin Drum Sander Belt ...
You are aware that tracking is counter-intuitive?
It once took me a very long day to learn that one.
It was the feed belt on a Performax dual head drum sander. The belt will run towards the longer side, not the shorter. I kept reading the instructions, but my brain would not allow me to understand something different that I already 'knew'.
