Portable 110volt banders
2/21/21
Harold
I have a great brandt Bander with premill and corner rounding. Dies a great job on modern flat panel 1mm banded panels.
I am thinking of getting a portable Bander that can do curves and also use occasionally at installs. Richelieu has one that comes with a small table that it fits into or can be used freehand. I have as looking on Amazon and found several Chinese portables from the 350-650.00 range. Any shops using these for curved work or for fillers and redos at installs?
I have rarely regretted spending on a specialty tool, even when used rarely as I find they save so much time. TIA.
2/21/21       #2: Portable 110volt banders ...
I recently bought a green one for one job. Haven't used it yet though.
3/1/21       #3: Portable 110volt banders ...
Derrek
Hands down the Festool portable bander. It uses a cartridge glue system is very clean and works great. Well worth the extra couple hundred over the portable glue pot machines
    • Wood Doctor's Rx, LLC
    • Template Services
    • ECabinet Systems
    • Denray Machine
