I have purchased a Casadei K320 edgebander. I have tuned and clean it up, and for the most part it works ok. However, there is a lack of glue on the leading 6mm of the edge being banded and thus the banding is not adhering well on those first 6mm. Specifically, it is the upper and lower corners of the leading edge that aren't adhering well. The rest of the panel is adhering very well!
Here's what I've done: glue pot is COMPLETELY clean and glue is fresh. Guide shoe is set 0.5mm away from the glue roller as per manufacture's suggestion. Glue temp is in the mid range as recommended by Jowat. Pressure rollers are set to be inline with the infeed and outfeed fence. I have tried removing all sources that may be "dragging" the banding as it first contacts the leading edge of the board (edgebanding roll, guide channels, guillotine cutoff, etc) - this does not seem to remedy the issue (I've watched closely and the tape is not pulling the glue back from the edge).
Any thoughts?? I'm at the point where I'm just going to cut my panels 18mm longer than necessary and trim the ends after banding. But that is more work. Any help/insight would be much appreciated.
