Pop up saws
3/7/21
The salesman is telling me a smaller blade will give me a better cut quality. This seems counter intuitive to me. I've always kinda ran with the bigger is better.
We don't need cut capacity, it'll be face frames and door parts.
Thoughts?
3/7/21       #2: Pop up saws ...
Dustin orth
I have a 16" and an 18". I think the 16 cuts better for finish cuts, a heavy plate blade will also make a difference. You can probably run smaller blades yet on any saw but would have to move the fence forward to make sure you cut all the way thru. I also believe a negative tooth angle and upcut cycle speed play a major part.
