Conturo
5/16/21
Phil Member
Hi,
I recently purchased the Festool conturo edgebander and the accompanying system for an upcoming closet job with 3mm edge banding. I know most of you guys are larger, industrial shops with stationary edge banders but I am wondering if anyone has experience with this system. The top and bottom of the banding will have a radius , but I am not sure how to deal with the ends, which I also was hoping to put a radius on.
5/16/21       #2: Conturo ...
Just get a laminate trimmer with a 3 mm round over bit and you can round over where ever you want.
I haven’t looked at edge banders for a few years, but I have owned Brandt, SCM and Holzer and none of them would put a round over on the ends.
5/16/21       #3: Conturo ...
If you go the laminate trimmer route go to someplace like amana and order a euro square bearing (non rotating). Nothing worse than a bearing streak down the center of your banding or right at the end of a long part that roaches the whole thing.
Newer high end banders round the ends but no contours.
5/16/21       #4: Conturo ...
cabinetmaker
Laminate trimmer with 1/8 bit. Light handed and fast. Blue masking tape on the banding face can help.
5/17/21       #5: Conturo ...
Phil Member
Scott, Mark and cabinetmaker, thanks for the responses.
5/17/21       #6: Conturo ...
Mark B
The square bearing (if you can find one with the rad you need) eliminates the need for taping to protect the banding from the bearing and gives a good bit more surface area to ride on. Its tricky to get combinations in bevel/rad but it works well when you can. The round bearings for me have always been a nuisance on PVC.
5/19/21       #7: Conturo ...
Derrek
Website: http://www.closetdr.com
we have had a Conturo in our shop for several years, great product that is 10x better than other portable contour banders.
We run mostly 1mm, but have done some 3mm as well.
a big help for finishing edges is a custom trim router from Betterly Tools. We have the laminate trim router with a radius bit in it.
for 1mm, we apply the banding, then trim it using a Fastcap Quick n Easy trimmer, then run the router down it to give it a slight radius/ break the sharp edge. on color pvc, we make a quick pass with a heat gun to bring the color back to it.
betterly laminate trimmer
    • Wood Doctor's Rx, LLC
    • Template Services
    • ECabinet Systems
    • Denray Machine
