Gouge size and log rolling
8/18/21
brad Member
Thought I'd get my moneys worth out of this one and ask two questions in one thread.
I'm about to start turning bowls and need to purchase another carving tool or two. Right now I've got one of the typical inexpensive 3 piece carbide sets off Amazon (pictured below w/o inserts) and from the videos I've been watching I'm gonna need a regular HSS bowl gouge and parting tool, and I'm wondering what size of each of these I'll need. I believe the size parting tool I've seen is described as 3/16"? so I suppose that's the size I'll order. And so far as the gouge goes I've seen them (in videos) in a number of different sizes. The turner I watch the most uses a 5/8" gouge but I'm wondering if that's gonna be too large to start off with. Since I'm just starting out my main concern is not doing anything quickly so if the only advantage of the larger 5/8" gouge is speed then I could probably do without it. Also, I've seen examples of dovetails being made in tenons with much smaller gouges, which is something I prob need to consider. Is there a middle size gouge that would do well for general bowl turning and tenon dove tails? What size parting tool and gouge would be best? Trying to save $ so if 1 gouge will do instead of 2 different sizes then that would make my day.
and...
I'm sourcing locally felled trees and have come across a really big log I can't get through with my 14" chain saw without being able to rotate is to get the bottom of the cut. My best idea is to get a log moving/rotating tool I've only seen in videos. Not sure what it's called but it's about a 5-6' long pole with a large hook attached about 1.5' from the end. Hook the log then turn it with leverage. What are these things called and what's the cheapest place to get one?
View higher quality, full size image (2173 X 1493)
8/18/21       #2: Gouge size and log rolling ...
rich c
Curious place to ask about bowl turning and log handling.
8/18/21       #3: Gouge size and log rolling ...
rich c
Plenty of hobby woodturning sites that can teach you turning better than youtube. Much better than asking on a professional cabinet making forum.
8/18/21       #4: Gouge size and log rolling ...
perley bowen
As a wood turner I would suggest that you find a local turning group for help. You are starting off with too large of a project. As far as tools check out Sam Angelo on You Tub. The log rolling tool is called a cant hook. Good luck.
8/19/21       #5: Gouge size and log rolling ...
Cant hook or a Peavey.
8/21/21       #6: Gouge size and log rolling ...
Kevin Jenness
This is really not the right venue to get your questions answered. Do a little archival research on the AAW forum and you will find what you want. There is a "getting started" subforum there.
turning site
8/28/21       #7: Gouge size and log rolling ...
brad Member
Ok, thank you for the direction. I post on a number of forums and forgot where I was for a minute there.
    • GreCon
    • CP Adhesives
    • Cabinet Pro
    • Palmetto Cabinet Doors
    • Anver Corporation
