using a tapered bit to cut kerfs for bending wood?
9/1/21
michael foster Member
I need to bend some solid wood and I am wondering if it is possible to use a Tapered Ball End Mill bit in a router to make kerf cuts instead of using the table saw? Can these cuts be made so the gaps close completely and are glued when the wood is bent avoiding having to plug or fill the voids?
9/1/21       #2: using a tapered bit to cut kerfs fo ...
duster
That would depend entirely on the diameter and angle of taper of the bit, and the radius you're try to bend to. However, a ball end bit is still going to leave a gap at the bottom of the kerf no matter how tight your radius is.
9/1/21       #3: using a tapered bit to cut kerfs fo ...
rich c
If you want zero gaps, strip laminate the solid wood. It's very difficult to not have any telegraphing of the kerfs if you intend to stain the wood. Plus you will still need to wet or steam the solid wood if kerf bent, unless you are using rift or quarter saw solid wood. Super easy to get cross grain cracking with kerf bent solid wood.
9/1/21       #4: using a tapered bit to cut kerfs fo ...
The material I am hoping to use is 1/4" sawn mahogany. It is a kitchen with curved fronts ,mostly drawers. The biggest radius is 16', the smallest is a little less than 5'. The grain is running horizontally and the curve the same. I would have to cut broad pieces of veneer to span the curves at the top of the fronts. (covering the kerf cuts). The cabinets are flush with 3/32" spaces between the fronts. The tops of the drawer fronts will only be seen when the drawer is open. With these radii do you still think steam will be needed?
9/1/21       #5: using a tapered bit to cut kerfs fo ...
Is their a bit that would taper into a point?
9/1/21       #6: using a tapered bit to cut kerfs fo ...
Adam Spees
This is typically done by cutting thick veneers(3/16 - 1/4") on the tablesaw. Curved lamination over a form. Its like making a curved jamb for a window or door. If you do it right you can barely see the laminations or the customer shouldn't care unless its fine furniture.
Kerf bending is typically done with a thin blade like one you use on a circular saw(1/16"). You could gap fill that with epoxy resin. But then you are still veneering the top edge.
9/2/21       #7: using a tapered bit to cut kerfs fo ...
Mark B
There is no tool that would cut a true V point with a shallow enough angle and even if there were your tip life would be nanoseconds. Additionally you'd need a specific tool for each radius.
If your not locked to solids and looking for a faster option just make the fronts thick and use two layers of bending ply glued/clamped over a form, edgeband, and veneer with the thickest material you can.
9/2/21       #8: using a tapered bit to cut kerfs fo ...
one of the requirements on the job is that it must be built of all local material. We do not have anyone making plywood or veneer in Barbados. If i am to use veneer it would have to be cut on a band saw. I may have to cut the kerf with a table saw and veneer the tops. I know I will have to do a bit of trial and error but how much wood should I leave when cutting the kerf.
9/2/21       #9: using a tapered bit to cut kerfs fo ...
Mark B
Sounds like you need to inform the author of the specification with regards to the cost of their spec' however if you bid the job without considered what it takes to fulfil the spec and they accepted your bid and are expecting receipt of product, then your kinda stuck.
9/2/21       #10: using a tapered bit to cut kerfs fo ...
This is a job I am doing for myself. I set the requirements.
Michael
9/3/21       #11: using a tapered bit to cut kerfs fo ...
duster
I made this arched valance using 3 plys of 1/4" african mahogany veneered mdf core panels.
I banded the bottom edge with an 1/8" thick strip of solid mahogany.
I spent most of a day making the form, laminating the panel, trimming the edges, and banding the bottom edge.
This was for my own house, I set the requirements...
View higher quality, full size image (1008 X 756)
9/5/21       #12: using a tapered bit to cut kerfs fo ...
still undecided about how to proceed.
I'm in agreement100.....with duster
Your best work should be in your home and in your clients home.
I am leaning towards kerf sawing with a table saw. Filling and painting to the kerf line with white , the color of the drawer. not sure how deep I will have to cut to facilitate the bending.
Michael.
5/10/23       #13: using a tapered bit to cut kerfs fo ...
Jeff Dains
SainSmart Genmitsu 10Pcs Nano Blue Coat Engraving Bits, 15 Degree 0.1mm Tip 1/8" Shank Conical V-Bit
would give a true V cut.
    • Impact Search and Placement
    • Original Saw Company
      Industrial Radial Arm Saws
    • Western Dovetail
      Custom Made Dovetail Drawers
    • American Fabric Filter Co.
