Metal Door Hinges
9/22/21
David Bienvenue Member
I am fabricating a metal, lited door with 1" stiles and rails. What kind of hinge could work well in that application?
Also, if we wanted soft close, would my only option be a product like a Blum added soft close damper?
Thanks!
9/23/21       #2: Metal Door Hinges ...
David,
Is this a lift up door. Are the stiles and rails metal with a glass panel? How wide and tall is the door? Do you know the weight?
With these questions answered, I can make a recommendation.
Dennis
9/23/21       #3: Metal Door Hinges ...
Doors are bi-parting, all metal stiles and rails that are 1" wide and 3/4" thick, door size is 9" x 37". They have not been fabricated yet but my best guess is they will be about 15lbs each.
I uploaded a few preliminary drawings, see attached.
Bar_Upper_Cab.pdf
Door_Details.pdf
9/23/21       #4: Metal Door Hinges ...
Kalvin
Website: http://woodhavencabinets.com
Salice Air Hinge
I recently did 6 narrow frame (1") aluminum doors. These hinges worked amazing. They look much better than any of the other hinges that you can actually see through the glass.
9/23/21       #5: Metal Door Hinges ...
Kalvin,
That's a cool recommendation and a pretty slick looking hinge. A couple follow up questions though...
-Did you use this hinge and the aluminum glass ready stiles and rails?
-If so, How did you machine your mitered aluminum to accept the Air hinge and corner bracket?
-Do they have non-hinge ready corners for assembling the non-hinge side of door?
Any advice on assembling these glass door units?
Really appreciate your advice!
9/24/21       #6: Metal Door Hinges ...
Kalvin
Hey, David. I actually ordered my doors from Element Designs. The doors come machined to accept the hinge. I only had to route out the cabinet box to install them. They come completely assembled with glass installed already as well. I just take them out of the box and install them straight onto the cabinet.
They are not cheap, I just let the customer know ahead of time it will be an x amount upcharge for the doors.
We are a cabinet shop, so I would prefer my guys to stay busy making cabinets, not trying to fabricate some metal doors.
    • GreCon
    • CP Adhesives
    • Cabinet Pro
    • Palmetto Cabinet Doors
    • Anver Corporation
