Construction boring machine vs lineboring machine
11/24/21
RODNEY BLACKERBY Member
looking at a construction boring machine for sale anyone know if you can do unlimited length's like let's say i wanted to drill a bookcase end, never used one of these machine i know the are used for boring for dowel's in framless cabinets. any thought apperciated.
11/24/21       #2: Construction boring machine vs line ...
Greg Fasolt Member
Is there any provision for a line boring fence? Perhaps contact SCMI?
11/24/21       #3: Construction boring machine vs line ...
Daniel
most machines of these machines can do any length and just by looking at it this one can also. construction and line boring
11/25/21       #4: Construction boring machine vs line ...
Keith Newton
By "Construction" do you mean to use out on the job site?
Back in the mid 80ies I made a bunch of jigs/ templates which use a plunge router with 18mm guide bushing and 5mm brad point drill to make it easy for small shops to convert over to the Euro method. However here in AR, I couldn't convince any of the knuckle draggers to give up their face frame habits.
However it's still a quick method. I can drill 90 holes a minute, or 1.5 per second.
I made one for base cabinets and one for uppers. The upper is 12" x 48" from 1/2" apple ply. There are 3 lines of holes, with the middle one for book shelves less than 12". All the holes have a small chamfer which acts as a funnel to guide the bushing in more easily. And of course the front line of holes is the right backset for hinge mounts.
I'm sure I can still find one back in the storage area if your interested, just drop me an email. Back then I had to get a machine shop to mill bushings to adapt the 10mm shank for 1/2" collet. Those are all gone, so you would need to find your own.
11/25/21       #5: Construction boring machine vs line ...
Joe Calhoon
I had this same machine years ago. FM 35 I believe. It was good for construction drilling in ends and faces of dowel holes in case work. Mine had extension fences for longer work. It could do line boring but was pretty unhandy for this compared to the Ayen machines. Line boring of panels longer than what fit between the fences was challenging and time consuming to set up.
11/25/21       #6: Construction boring machine vs line ...
Dave L
It looks like the hold down bar supports could be reconfigured - so that the uprights are at the back of the machine - to allow for line boring long material.
You would need to add a longer back fence with accurately spaced stops. With 35 spindles, two stops 1120mm apart would give you an ~87" row of holes.
11/25/21       #7: Construction boring machine vs line ...
Joe Calhoon
Correct, the clamps could be moved and the fence could also be be run the other direction and the 2 fences connected together. Drilling line holes involved moving fences and clamps a lot. It was a very robust machine, solid cast iron construction.
11/30/21       #8: Construction boring machine vs line ...
Jim Kolar
I have this machine and we use it for confirmat drilling on our end pieces. Tried line boring before cnc and I agree with Joe that it was a lot of set up time. Prior to cnc I had a ritter 23 spindle line bore machine that worked fine. The 35 is a solid machine and has kept its tolerances.
    • Limtech Industries, Inc.
    • Denray Machine
    • Cabinet Pro
    • Impact Search and Placement
    • RT Machine Co.
