Teak veneer.
12/25/21
dr Member
What is the best way to glue teak veneer for a marine environment? Could I use the stick on? Thanks
12/25/21       #2: Teak veneer. ...
Absolutely don't use adhesive backed. Having something mounted on a boat with tape is a disaster! I use Unibond 800 on furniture, never worked on a boat.
12/26/21       #3: Teak veneer. ...
dr Member
Unibond looks good but I don't have clamping capabilities. I wonder if epoxy resin with a fast hardener will work using a roller.
12/26/21       #4: Teak veneer. ...
james e mcgrew  Member
Epoxy resin medium to slow hardner with a vacuum bag, I have wrinkled tiger strip walnut on door panels on my sailboat, i told the guys to use a pva adhesive yet the moisture was a well practiced enemy.
On the boat i have a a freshwater lake it is not so bad, on the boat at the coast it gave loose. replacing all now.
12/26/21       #5: Teak veneer. ...
dr Member
Can't use a vacuum bag either.
    • Wood Doctor's Rx, LLC
    • Template Services
    • ECabinet Systems
    • Denray Machine
