Ritter style clamp system build
2/27/22
Jeff
Just interested if anyone has built a clamp similar to the Ritter one for use for building cabinet doors.
I don’t have a ton of space and I will do a set of doors and then it will be awhile before I do another set so would like a smaller version as most doors in a kitchen are less than 2 ft x 4ft.
I think it would be fairly easy to build the frame and table out of sheet goods and hardwood, or maybe even some aluminum.
The part I am unsure about is the clamping pressure required? And what type of cylinders to use?
2/28/22       #4: Ritter style clamp system build ...
Bill Member
Aren't you insanely busy building product? How do you have time to build a clamp? If you do I have time I would spend it getting more business. This is the hottest market since 08.
2/28/22       #5: Ritter style clamp system build ...
Jeff
Bill,
You have a valid point, but I didn’t think it would take long to build something that would really save time in the future. I currently use bessey k-clamps and Ibeam clamps:
2/28/22       #6: Ritter style clamp system build ...
Jim
There is a smaller footprint clamp in the machinery listings
3/4/22       #7: Ritter style clamp system build ...
Tipper Member
The table is the easy part. You can build it out of ply and drill the 3/4” holes yourself. The difficult part is finding clamps that will mount in the holes and have their piston rod rest flat on the table throughout its travel length. I suppose you could build some wood cradles with pegs to hold the clamps. You would need to find a pic of a Ritter pneumatic clamp to clone it out of wood. Or you could just buy the clamps from Ritter. They run $450 each and you would need at least 3 or 4. These clamps almost never come up on the used market without the table too.
I could use some of the Ritter clamps if anyone has any they could spare. LoL! Seriously!
As far as getting after market clamps. You could use a piston style cylinder clamp that retracts back pneumatically. I would get one with either a 1/2” or 3/4” bore with around 6” of travel. You will need 1/4” plastic air line, elbows, tee fittings and a valve to turn the air on and off. Good luck! If you find a way to make aftermarket cylinder clamps work I would be amazed and would probably clone your design!
3/6/22       #8: Ritter style clamp system build ...
keith farr
Built a crude one thrty five years ago. Got a peice of sheet steal and backed it up with a sheet of 3/4" plywood bolted a 1x1 angle iron across bottom and up one side chalk lined a grid on it and drilled bunch of 3/8" holes added some iron legs with table on tilt Then took some air cylinders that I had and stock a 3/8 piece of all thread out the bottom of an existing hole ( let all thread stick out the bottom about 1 1/2". Cylinders had about a 4" stroke so didnet need many holes in table I put a small vavle at table waste high to turn and activate air and I put a release valve on the cylinder with a large ring to pull on to release air ( just pull release valve and push cylinder back with other hand I used it for many years It was aliitle out of square so I just made a slighly tapered piece of wood to lay against fence to compensate It had three times the power of my current riiter clamping table You would not want to get a finger in it Sold it to a young guy starting a new shop last year for couple hundred bucks and he's making money with it One day he will be in a position to sell to another to help them get started When I say crude i mean crude I was a kid with no Welding skills but access to lots of scrape pipes and metal Thats how I did alot of stuff when I started... I do agree if you need it due to business you have allready paid for it but doing stuff like that when I started put me where Im at today able to buy anything I need Good luck
    • Air Handling Systems
    • Denray Machine
    • Western Dovetail
      Custom Made Dovetail Drawers
