Struts for cabinet door
3/13/22
Randy Stone Member
Making a cabinet for an exterior flat screen TV and the client wants the door to lift up. It will be approx 55X36. Stiles and rails will be 1.5" x 4" with 1x6 t&g as the panel. I suspect it will weigh between 35-55lbs.
I want to use some gas struts that will help lift and perhaps also hold the door in place. Looking for help with finding struts.
I'm not sure if it matters but using butt hinges so I can use Qlon weather stripping for a tight seal.
Thanks, R.
3/14/22       #2: Struts for cabinet door ...
duster
I've done a few pieces with lift up doors supported by gas struts. I've found them at auto part stores and Amazon.
The struts come in a wide variety of load capacity, and it's a bit tricky to get the correct ones for a particular application. Where you mount the strut on the door and the cabinet sides can make a big difference in how well the struts support the door.
I'd suggest doing a mock up with some scrap to verify that you have the correct strut and mounting points. It took me a few tries to get the correct strut and get the door working properly on the fly rod case shown.
View higher quality, full size image (800 X 575)
3/14/22       #3: Struts for cabinet door ...
Mark B
There are several calculators from manufacturers
3/14/22       #4: Struts for cabinet door ...
Mark B
Sorry.. link
3/14/22       #5: Struts for cabinet door ...
Mark B
Now this is a little irritating lol one more try
https://www.bansbach.com/index.php/en/products/gas-springs/calculation
3/15/22       #6: Struts for cabinet door ...
Peter Rusterholz
For outdoor application you could also use hatch springs.
https://www.hardwaresource.com/hatch-spring-support-stainless-steel.html
I use them for fish tank lids.
3/15/22       #7: Struts for cabinet door ...
Randy Stone Member
Website: http://www.dovetailconstruct.com
Thanks All for the tips!
