Commercial Kitchen Construction and Assembly
9/3/22
Rich Member
Website: rosewoodnyc.com
What is your Quick and cheap construction and assembly method for commercial kitchens?
I am trying to come up with a construction method and a material type to use for your most basic white kitchens. I was thinking white melamine construction with Rafix Connectors.
As a GC on our Lower End Commercial projects, our kitchen vendor would supply us cheap import cabinets 3/4" construction all around, No Dado, Cam lock and dowel connections., Plywood core MDF, frameless construction, Berta Soft Close Hinges, adjustable shelves. Doors are Laminated Particle board. Its works and we sell a fair amount of it.
We are using Cabinet Vision
Holzer 1057 XL C Edge Bander
Rover K 5x10 CNC
No other kind of line boring / edge drilling equipment.
9/4/22       #2: Commercial Kitchen Construction and ...
JK Interior Finish Inc.
With that equipment you could use qualified dado construction and screw together with cinfirmat screws , or buy a dowel machine and a case clamp
Either way will be much stronger and faster than cam systems .
