How to prepare doors for JLT door clamp
5/9/23
Mr Fee Member
I'm considering purchasing a JLT door clamp. Is there anything I need to know in terms of preparing door parts? Will this machine work with a panel that is undersized? I leave about 1/16 of space for my flat panel doors.
5/9/23       #2: How to prepare doors for JLT door c ...
I don't do anything different.
Back off the pressure on spongy material like alder.
Otherwise, apply glue. Assemble. Clamp. Go onto the next
5/10/23       #3: How to prepare doors for JLT door c ...
perley
You don't need to do anything other than glue and stick in clamp. I leave the pressure on the door while i glue the next one. I don't use space balls. But you might need to pin the joint if you do. The doors come out square. No need to measure across the corner to check for square.
    • GreCon
    • CP Adhesives
    • Cabinet Pro
    • Palmetto Cabinet Doors
    • Anver Corporation
