Dado set
5/31/23
I picked up a nice old radial arm saw, it is a Rockwell 14 inch with a 5 hp motor.
I wanted to put a dado set on it to cut some bigger tenons. I was wondering what diameter/ number of teeth I should be looking at for cutting solid hardwood? The arbor is 1 inch.
5/31/23       #2: Dado set ...
premiere kitchen designs
Website: http://premierekitchensllc.com
I set up my shop to be very universal.
All my saws (4) take a 10" blades. All work great with a 10" dado.
My streibig the only saw with 12" blade.
So a 10" dado set could be universal.
6/1/23       #3: Dado set ...
You do not need to be a tooling technologist.
Radial arm saws with dadoes can be viewed as uber dangerous, so be sure to have your return spring in good shape, as well as everything else. Were it my shop, I would look at alternate ways of making such cuts.
6/1/23       #4: Dado set ...
I worked with a couple Rockwell Radial saws that had 1/4” aluminum plates fastened to the flat underside of the motor, projecting out to the right enough to support a router. A 2” diameter flat bit was spun and worked like butter, with no fear of the motor coming out at you. Excellent for dental mold as well as unusual tenons, half laps, etc.
6/2/23       #5: Dado set ...
warren e Member
for cross cutting on radials you should use negative rake blades. Dadoes come this way as well. Maybe you can use insert heads as well but would not have negative rake but would have the nanny state limiting
Cheap radials will creep more they are weaker lighter and flex making it easier for them to climb.
We were taught you keep your arm straight when you cross cut and it was clear doing that right away the saw cant creep as you hold it back where there is no material. Ive seen them walk forward on people cross cutting with a bent elbow. Keep your arm straight and you will be fine.
6/8/23       #6: Dado set ...
The diameter of the dado set should be based on the work you are planning on doing with it. Typically a 10" tablesaw or a 10" radial would use an 8" dado set. You have enough hp to spin a 10" dado set, but the cost would be very high and do you need it?
    • GreCon
    • CP Adhesives
    • Cabinet Pro
    • Palmetto Cabinet Doors
    • Anver Corporation
