Edgebander
4/4/24
Joe Member
I just got holzher auriga 1306 edgebander and the little drive belt will not turn on . Everything else works but fist station will not feed tape . Is there a fuse that is blown ,? Any ideas would be helpful
4/4/24       #2: Edgebander ...
If you can't troubleshoot electrical components, hire an electrician.
4/4/24       #3: Edgebander ...
Dave Edgerton  Member
Possibly blown fuse. Grab a multimeter and check them for continuity. Wehad buffing unit shut off and it was a fuse.
4/5/24       #4: Edgebander ...
Joe Member
Dave could you send a picture of the fuses . I think I know what they look like but would like to know what for sure
4/5/24       #5: Edgebander ...
It will look like this. About 1" long, 3/8 diameter.
Shoud be located in the lower deck of the machine.
View higher quality, full size image (768 X 768)
4/5/24       #6: Edgebander ...
Joe Member
My machine is single phase I don't see any fuses like that it's a 2009 my older smaller bander has some fuses that look like that . I looked and don't see anything like those in bottom of cabinet
4/5/24       #7: Edgebander ...
Jim Herron
Be sure you don't have some edgebanding tape or something else blocking the photosensor that triggers the tape to advance.
4/9/24       #8: Edgebander ...
Joe Member
The photo eye is lit up and not blocked found the fuses they are all good . My buddy went through the electrical components and there is no power to the top side of transformer. We moved the machine from one shop to another about five miles . I seen a old post to make sure all connections are tight . Everything is works on machine
4/13/24       #9: Edgebander ...
Joe Member
There was a wire that was pushed in to far into a contactor from the factory .It must have moved during the move but it was crimped on the insulation part of the wire not the bare end . The photo eye needed adjustment but not much took my buddy 4 hours to trace problem out
