Computer Aided Design
Subject: Re: Edit cabinet in Cabinet Vision
10/8/13
Max
I trying to edit cabinet in cabinet vision
But when I divide cabinet in 3 door section doors is showing but inside partition not showing . How I can change setting that CV automatically insert partition?
10/8/13       #2: Edit cabinet in Cabinet Vision ...
Leland Thomasset  Member
Hi Max,
You need to hit the section interior tab and add the fixed shelves or partitions. Partitions will automatically place themselves into a empty cabinet. If you need help I do CV consulting and training.
Taghkanic CNC Services
10/8/13       #3: Edit cabinet in Cabinet Vision ...
Bob
When I place interior fixed shelf . Shelve doesn't follow opening and I need to adjust each time manually and that is more chance to make mistake
10/9/13       #4: Edit cabinet in Cabinet Vision ...
TomB
When you are adding interior fixed shelves or partitions, make sure and click on the dashed grey line if you want them to follow the face sections.
10/10/13       #5: Edit cabinet in Cabinet Vision ...
Bob
i do same way but partition not follow door after i change door size
10/10/13       #6: Edit cabinet in Cabinet Vision ...
Bob
Looks that works now.
