Computer Aided Design
Alphacam Vba Query
8/31/20
Harshada Member
Hi,
How can I change default printer in Alphacam using VBA.?
Actually I need it to save my current drawing ard files in pdf.
9/1/20       #2: Alphacam Vba Query ...
dan
Dont have alphacam but I'm guessing it's the same or very similar to the process in excel vba.
Search (printing-in-vba) at exceltip.com.
9/1/20       #3: Alphacam Vba Query ...
David Wishengrad
You will need to check the developer API. In AutoCAD, you can't just print to a default printer unless you use the Windows API, leaving only a direct route through code where you must specify the page setup settings, sheet size and the rest, and it may not be the same names you are accustomed to seeing.
Open the watch window in debug mode and drop in the calls and see that they return too. That can help you identity the exact names to specify.
Reposted due to typos on cell.
    • INNERGY
    • ECabinet Systems
    • Cabinet Pro
