Computer Aided Design
cutting veneer with an aggregate saw blade
10/25/22
Mark Hurley
Website: http://mhurleyinc.com
Sounds simple.
Looking for software to cut sequence matched 3/4" mdf core veneer panels.
I have a Homag CNC and a Benz aggregate saw blade. We have been using Woodwop and also importing DXF files. Both applications are time consuming and present challenges.
I typically order in veneer sheets that have been pressed specifically for the project at hand. A long island run would have two panels sized at 8' x 3' x 3/4"
Is there a software that will cut the squares with the saw blade and clean the corners with a 1/8" router bit.
I would like to adjust the sizes and composition in some sort of spread sheet or field instead of stretching and or adjusting the tool path.
Like I said, sounds simple but is anyone doing it.
10/27/22       #2: cutting veneer with an aggregate sa ...
Woodwop is all parametric. That's what I would be doing it in. Or, I'm misunderstanding and not seeing the whole picture of why it wouldn't work well.
6/13/23       #3: cutting veneer with an aggregate sa ...
Jamie Oliver Member
I recommend EnRoute which is a CAD/CAM software known for its advanced nesting capabilities and toolpath optimization. It offers features for designing, nesting, and generating code for CNC machining. EnRoute supports various file formats and provides efficient solutions for cutting and routing operations.
    • The Millwork Studio
    • Cabinet Pro
    • ECabinet Systems
