Computer Aided Design
Biesse Automatic Import Pocket Support
5/28/23
Michael Member
Does anyone know if the automatic import function in BiesseWorks can support pocketing operations?
I need to automatically program several nested sheets for a Biesse machine and this would streamline things immensely if it were possible.
Any leads would be appreciated, thanks.
5/30/23       #2: Biesse Automatic Import Pocket Supp ...
David Wishengrad
TCHB1W0TCD$13$S18000F20000TC2D3750
That is an example of a layer name it can import having a centerline path for the pocketing already drawn. The tool being used is 13. the $ is an undocumented override command to use the tool specified, s is the spindle speed, f is the feed rate, D3750 is .375 (the depth of the cut).
BW does not have its own pocketing function the last I looked. if you can generate the geometry for the actual tool pocket path, properly name it and include it in the dxf, it will do it.
6/3/23       #3: Biesse Automatic Import Pocket Supp ...
David Wishengrad
Michael,
It is possible to use netDXF to create pocket paths of your chosen geometry for free and add the layer naming info too.
Many different possibilities exist for paths to cut a pocket. circular patterns, spiraling, where to start and end. By writing it yourself once you will have full control and can make improvements over time.
If this is a one time thing, then it won't be worth it as far as time allocated to this job, but it will probably serve you far better in the long run to have serious control over your work flow by having the ability to do whatever you need to do with automation in the areas where deep software control can be useful. Just my 2 cents.
6/7/23       #4: Biesse Automatic Import Pocket Supp ...
Michael Member
Hi David
Thanks for the feedback. I did resort to drawing the pockets manually to program them as milling operations. But thanks for pointing me to netDXF. I'd not come across it before.
I've since moved to working on more basic CNC with standard g-code. I'm wondering if anyone has programmed netDXF to generate g-code? It would be a very powerful automation tool if it could.
6/7/23       #5: Biesse Automatic Import Pocket Supp ...
David Wishengrad
Michael,
As long as you have something to view the dxf's in to verify that they are correct I may be able to throw together a G-Code app for you.
Drop me a line and we can talk if you are interested. Nothing fancy, but you will be able to modif the working code yourself and improve from there.
Have a good one.
davewishengrad at gmail.com
6/13/23       #6: Biesse Automatic Import Pocket Supp ...
Charlie Jone Member
The BiesseWorks software does support the automatic import function, which can be helpful for streamlining programming tasks.
    • ECabinet Systems
    • The Millwork Studio
    • CabMaster Software
