Subject: Re: CNC MDF shaker doors advice
2/19/16
WoodRob Member
As simplistic this may soud, Looking for some experianced advice from one how actualy do or did MDS shaker style doors on a CNC.
I know the basisc, rout the pannel to make the resess part !
BUT....there’s more to it !
What’s exectly the routing steps & cutting strategy to make a nice flat center and....noce crisp inner corners ?
Then, before painting, there’s the routed marks, as little the may or could be, has to be sanded ?
Just an all & all advice from an experiance one to make this....more efficienat and possibly...proftible, as there is just to many one “dumping” this style / type, I’m requested to make for a Kitchen ...;0( !
Thanks, Rob
2/19/16       #2: CNC MDF shaker doors advice ...
Robert Member
YOupss....sorry for all those typo mistakes !!....English not my mother tongue +...did it a little to fast from of my tiny tablet...sorry, but on the other hand, I think it’s still...understandable ;o\\
Tks...
2/19/16       #3: CNC MDF shaker doors advice ...
The quality of the MDF is critical.
We have tried lots of stuff, but ended up using only Plum Creek.
Diamond tooling
2/21/16       #4: CNC MDF shaker doors advice ...
Robert Member
Anyone ever did such type of recessed / bottom cleaning ( call it anyway yu wish) work with CRISP inner cornering out there,
Anyone ??
Care to share how ??
2/21/16       #5: CNC MDF shaker doors advice ...
Paul S
One answer is to make a two pc mdf door. First cut out the frame and dado the back side from 3/4 material . Then cut the Panel using 3/8 material with 1/8 dado so when inserted into frame you will have that 1/8" reveal in the back of the door. Now you will also have a balanced panel less likely to warp
2/21/16       #6: CNC MDF shaker doors advice ...
Robert Member
Thks Paul.....but NOP !!...it has to be out of one pieces only !!
2/21/16       #7: CNC MDF shaker doors advice ...
2" tool in the pocket, 1/2 on the inside perimeter of the pocket 1/8 on the inside perimeter of the pocket.
Done.
2/21/16       #8: CNC MDF shaker doors advice ...
Robert Member
Dropout....if a paint base coating is applied after, say white, then some clear coat, do you bother sanding the 2nd & 3rd tooling makes ( if ever)??.... ( those form 1/2" then 1/8")
Tks
2/21/16       #9: CNC MDF shaker doors advice ...
Jason Scott
I use a 1 3/4" diamond for the field, then a 1/2" up spiral for the perimeter inside, then an 1/8" in the corners then I use a small beading bit to break the inside edge. We use plum creek HDF. You have to be very careful not to leave sander marks when you sand the panel inside.
Double coat your primer. We do a wet on wet coat with conversion varnish primer.
3/2/16       #10: CNC MDF shaker doors advice ...
Bill Hagers
Not a fan of MDF doors, each to their own. If you have to do this though don't fuss with pocketing perfectly, it will always have some lines and require hand work that way. Pocket it out and make an insert piece of MDF to slip in place, glue it in place and the filler will make up a nice paintable inset face. 1/8" mdf works well for this.
3/2/16       #11: CNC MDF shaker doors advice ...
Robert
Thks Bill....the problem I've been with this alternative, is some client "hate" the back side look, they rather have the smooth no cut backing when opening the door !
