Subject: Re: pc front end or full control
9/12/17
dave schiller
Website: http:/www./builtins.com
looking at a new router whats the difference between a pc front end and a full controller.in laymans terms
9/13/17       #2: pc front end or full control ...
Mark T
PC Front End = PC interfaces with proprietary cnc control. The proprietary portion of the control is still there but is networked to a PC also on the machine. You have all the advantages accociated with PC's (easier networked, larger storage space, simpler navigation, easy to set up for online support,etc)
Proprietary Control - typically is a stand alone unit that is only there to run the machinery. Older Fanuc controls are a good example of these. These also can do a lot of the functions above but are more rigid and typically lack a "windows" style operating environment.
The above is as applies to industrial controllers.
There are also "hobbyist" or "open architecture" options that use a PC and specific boards to control machine motion.
Hope this helps
Mark T
9/13/17       #3: pc front end or full control ...
dschiller
So is one better or is it just easier?
11/3/17       #5: pc front end or full control ...
Jeff
Website: coloradocncshop.com
There are some things that you cannot do on a PC control depending on what the actual control card is. A good example is something like a G51 as opposed to a G5. Complex curves can be done faster (usually) on an industrial control. I am not saying in every case but I would ask about it. In my experience a PC based control will work fine for most people, it really just depends on how much control you want to eventually have over your machine.
