Subject: Re: cnc nesting cabinet assembley
12/29/17
a.g. Member
hello all
i am wondering if their is any way possible to assemble laminated board cabinets with no screws and no horizontal boring ??
something like rafix fitting ?? for example a 2.5 meter cabinet to be assembled with no showing screws or horizontal boring just vertical boring using a cnc router
thank you for sharing
12/29/17       #2: cnc nesting cabinet assembley ...
Leland Thomasset  Member
Take a look at these
http://www.csaw.com/lamello/lamello-system/lamello-cabineo/
1/2/18       #3: cnc nesting cabinet assembley ...
Michael Cassell
Website: http://holzher.com
Link below will take you to video of unique system for nesting to utilize Lamello Clamex fittings on Holz-Her Dynestic CNC router
This process does require 100 mm of space between horizontal fittings
https://www.youtube.com/watch?v=a8LK8GF-9-I
1/2/18       #4: cnc nesting cabinet assembley ...
cabinetmaker
you can design a modified tenon and and cut a 3/8" mortise, although you would have to perform a secondary process on a table saw, shaper or router table we built a few cabinets with this and haven't had any problems with them they are glued with Titebond 2
1/2/18       #5: cnc nesting cabinet assembley ...
Have you looked at Cabinotch?
1/7/18       #6: cnc nesting cabinet assembley ...
Derrek
Yes. We build cabinet boxes with Cabinet Vision and our cnc using a blind mortise and tenon and rafix connectors on finished ends and screws on unfinished ends. We have no secondary machining, everything is completed on the cnc
At some point this year we will be moving to the Lockdowel system. It does require secondary machining on the horizontal drilled parts. Assembly time will be reduced and offset labor of secondary machining.
1/7/18       #7: cnc nesting cabinet assembley ...
a.g. Member
thank you all for your response
i am working with double faced Laminated Particle Board
so blind mortise and tenon are not an option i think
i am looking to use something like lamello-cabineo
1/10/18       #8: cnc nesting cabinet assembley ...
Derrek
We use blind dado. Don't know where I got mortise and tenon from.
1/10/18       #9: cnc nesting cabinet assembley ...
I assume you looked through the Hafele catalog.
Here is the Titus catalog download
http://www.titusplus.com/file/45825/2016-connectors-usa.pdf
There are lots of connectors of that nature.
1/10/18       #10: cnc nesting cabinet assembley ...
cabinetmaker
http://www.tenoncam.com/
1/20/18       #11: cnc nesting cabinet assembley ...
Chris Wilmot
Website: http://www.Lockdowel.com
Lockdowel is a hidden fastener system that requires only a router bit that we sell. Check out the website. No glue, screws, clamps or tools required to assemble.
Eclips_Ad_w_Cusotmers.pdf
