Subject: Re: omnitech error
omnitech error
10/30/18
Todd Member
I am new to this omnitech selexx mate. I am getting an error and I don't know how to fix it. the error is : number 1 tool must P reset
any help would be greatly appreciated. I paid for setup and training but I am still waiting for training and the shop is getting behind everyday.
10/30/18       #2: omnitech error ...
Leland Thomasset  Member
Try this make sure you have a tool in the spindle
Note which position of the tool carrier is adjacent the tool in the spindle
Put machine in MDI type M97T? which ever tool is suppose to be there ie; T11-T18;insert M94T? same tool number ; insert run nothing will move you will just see the commands execute on screen.
10/31/18       #3: omnitech error ...
Rob Young  Member
Website: http://www.cmsrepair.com
Is the error code you listed exactly what the alarm code says? A common error is tool 1 must be preset. If you are using a Fanuc controller this would be the M code. M97T1? The question mark would be whatever tool is in the spindle. If there is no tool it would be 0. Here's an example of the code if you have no tool in the spindle. M97T10 If tool number 1 is in the spindle it would be M97T11. If you have the Syntec controller the code is similar, M197T1?
Hope this helps.
10/31/18       #4: omnitech error ...
Todd Member
The exact error code
(2012) (A1.2) #1 tool number must p reset
if I continue past that I get the following second error code
EX1000 (2000) (A0.0) #1 spindle tool C
10/31/18       #5: omnitech error ...
Bob Lewis
Good advice in the earlier replies. I have had the same router for 8 years. It is, and has been a very good machine for us.
10/31/18       #6: omnitech error ...
Todd Member
Thank you to all that helped. That problem is resolved.
