Subject: Re: Glue pot machine for smaller shop
2/11/22
Pdub Member
Yes, this is an edgebander question in the CNC forum. Seems like the people who know higher level banders best are in this forum more. Posted a similar question elsewhere and didn't get much feedback.
We are a 4-5 man shop that does both Faceframe and frameless. Our frameless is 95% 1 mil wood tape. Because of that the bander will sometimes get used for a week and then sometimes sit idle for a week. It's also not uncommon for us to turn it on to only run 2 panels that got missed or screwed up. Our old Holzher with the puck system is very nice with the fast heat up time and not cooking the glue too much.
That machine needs to be replaced and I'm looking at a new Holzher and a Biesse. I've never had a glue pot. Given the parameters above are we better off sticking with the puck system? We generally use "natural" color and rarely change colors. the glue pot has a 10 min. heat up time which doesn't seem horrible. It also goes to standby and lowers the glue temp after some idle period. HH has reportedly improved the Glujet system since our old machine and dealt with what we considered the more annoying traits of it.
2/13/22       #2: Glue pot machine for smaller shop ...
Mark B
I cant give you any info on a glue pot machine but we have a holz-her cartridge style bander and seem like we operate much in the same way you do. Runs for a while on certain jobs then may sit, or may just run a few shelves or a door or two on certain days. From what Ive known of glue pot machines in other shops and what Ive read here I'd be hard pressed to move away from the cartridge at my volume.
2/14/22       #3: Glue pot machine for smaller shop ...
Gregory Fasolt Member
I have owned both glue pot and Holzher machines. In a non-production shop I would only consider the Holzher.
2/14/22       #4: Glue pot machine for smaller shop ...
Jared
I'm a small shop same size and body count as yours, and have a newish glue pot machine. I like most everything about it except for the glue pot heating time. On cold days it can take 20 minutes or longer to preheat, and takes some planning. I wish it had an alarm or flashing light that would alert me across the shop that it's ready.
I looked at the Holzher and only went in another direction because they don't seem to have much of a presence in my area.
3/1/22       #5: Glue pot machine for smaller shop ...
Dan
Previous to running HolzHer, the shop I am with had edgebanders which used a glue pot and roller. Personally I like the HolzHer system better. The HolzHer system has fewer moving parts, which has resulted in fewer issues. Glue Pots require more maintenance than the cartridge systems also.
If you current bander has given you little reason to look at another supplier I would stick with them.
