Subject: Re: Gantry Squaring
Gantry Squaring
3/1/22
Chris
Is there a more accurate way of checking the squareness of large panels than measuring corner to corner with a tape measure?
3/1/22       #2: Gantry Squaring ...
Jared
Cut 2 large panels, flip one, stack, check the corners. This will magnify a misalignment by 2x.
3/1/22       #3: Gantry Squaring ...
Mark B
At one time playing around I made a swing fixture that hooked on the corner of the panel and had a 1" travel dial indicator to check corner to corner. Your other best method is to square the panel then machine a strip of the long edge (whatever width your capable of measuring) and check it with a micrometer from one end to the other. Basically the 5 cut method on a table saw. The issue becomes how large a machine and how accurate to you actually need to be over a long length (100-120 inches).
If you have a true parallelogram the diagonals will still equal and you wont be square. Would seem rare but possible.
A good read (if you need glasses get a pair of readers) on a tape for diagonals is pretty damn accurate but if your in the parallelogram...
3/1/22       #4: Gantry Squaring ...
Jared
MarkB, I'm not picturing how a parallelogram would have equal diagonals. A trapezoid yes, but parallelogram? Explain!
3/1/22       #5: Gantry Squaring ...
Chris
thanks guys, lots of good info.
3/1/22       #6: Gantry Squaring ...
Mark B
Sorry Jared brain fart..
3/1/22       #7: Gantry Squaring ...
Jared
Semi-related. Chris, depending on what you're trying to address or fix, I've run into a situation where parts coming off my CNC were out of square because of tension in the panel being released during the cut. Big rectangles turned into bananas. The solution was to cut parts oversized by 1/16 and then finish cut to size. It only happened with a particular batch of Ranger MDF.
3/4/22       #8: Gantry Squaring ...
Kevin Jenness
Trammel points on a long beam.
3/15/22       #9: Gantry Squaring ...
Acctek  Member
You can draw an auxiliary line first to measure
3/15/22       #10: Gantry Squaring ...
yaakov Member
we found final solution for this problem
our gantry is one picee,and machining as one piece
no any word about squaring any more
attach our engineer test the gantry in turkey before shipping to israel
https://www.youtube.com/watch?v=ahzv8Qi1Su8
