Hello All
Hope the Holidays have been good to you.
Thanks in advance to any who answer or understand what i am doing....
Here is some background. For the last 25 + years I have been doing 32MM frameless cabinetry.
Using a Scheer 21 spindle Line borer, Fast ,pnuematic stops and fences.
Ritter RVH46 construction borer,SCMI Slider, Brandt Ambition1110FSB Premill, 5K sq.ft shop(own) in N.J.
Been doing great with this ,no problems, Yes it's CMC, Completely Manually Controlled.
W'ell I figured out my Smart phone so I figured I could do this...LOL
Just recently I purchased a Masterwood Project 317 PTP.
Got it from a shop that kept it in good shape at what I felt was a good #$.
Had a tech here to set and calibrate for 3 days back in November.
It has a drill block with a 9HP Router ,4 position ATC, new BVC pods.
The guys are doing present jobs CMC , while I am learning Masterwood Cad at the machine and on my laptop.I know this may take a while.......
I have taken a "Stock" kitchen side,24" X 30 1/2" ,CMC'd it and diagrammed out every possible pattern that we do now.
Got line boring patterns down for hinges plates and slides for all our door and drawer heights.
Trying not to change the Ritter patterns, PIA..
I presently put the dowel holes starting 28MM from the front,8.5MM from the outside. Then 96MM back for a 4" stretcher.
Now that I can do this on the PTP,do any of you reverse this pattern for a rear stretcher ?
I Have a 1/4" Down spiral for grooving the 1/4" back at 19mm in from the back.
So I feel I can do also 19mm + 28mm to bore for this.
Does this make any sense ?
Have read and re-read all the Knowledge Base on this and still ...
Also thanks to woodweb and guiding me to get some compression bits from Vortex to start cutting out my PCB & DCB's on the PTP,
That's another thread....
Tom C
