Bidding CNC Machine Use
4/6/16
BigTup
We just got our Pratix, and I use an estimating software and I apply times to all the operations in building cabinets. I was thinking of charging a flat $50/sheet for CNC time to run each sheet in a job. That should allow time to load the sheet, machine it, unload, clean the table, load the next sheet, and also time for maintenance. How does this sound?
4/6/16       #2: Bidding CNC Machine Use ...
What type of machine is it?
I have a 5X10 with a drill bank.
Average time to cut a sheet of cabinet parts is about 5 1/2 minutes. Add 5 minutes to load/unload for a total of 10.5 minutes. Even at 80% efficiency to allow for maintenance I get 13.125 minutes per sheet. At $50.00 per sheet that works out to $228.57 per hour.
That will skew your operating cost high and may make you uncompetitve.
4/6/16       #3: Bidding CNC Machine Use ...
Steve Member
I would add depreciation of the CNC to my operating cost as well
4/6/16       #4: Bidding CNC Machine Use ...
Steve Member
Also account for your tooling costs
4/6/16       #5: Bidding CNC Machine Use ...
BigTup
I was kind of thinking that I was landing jobs with job times that allowed for cutting panels on a slider, and processing parts on a point to point. So why not keep the same pricing with a CNC? If work slows I can lower my price to stay competitive. Get my drift? The machine is a 5 x 12, 10 position tool changer, drill block, rake.
4/8/16       #6: Bidding CNC Machine Use ...
Gary B.
Big Tup,
You and your company invested in technology and equipment be more efficient, and hopefully more profitable. Why give that away? I'm all for costing, and making sure we are making money, but at the end of the day the best profits are made by charging what the market will bear, not following some ambivalent guideline on how much profit a shop "should" make. If you have a productive, efficient machine (yours sounds like it fits this bill) then I don't think $225/ hour is really out of the question.
There will always be someone out there willing to do it for less. Impress with service and quality. Just the other day I was contacted by a shop that regularly outsources their CNC and banding work. They informed me that they are used to paying $15 per sheet for CNC work, and $20 if CNC and banding is required. I informed them they should continue using whoever was willing to get paid that, and continue doing business. That would barely cover my time to ensure their programs don't harm my machine or tooling. (If they are even programmed in a language my machine can understand), let alone the tooling, electrical, overhead, and personnel to carry out their project.
I would suggest working on a basis of time, not money for this. That way later down the road you can review the time and make sure you're meeting/exceeding this goal.
