V Carve wrapping question
2/1/18
duster
I'm a cnc rookie making my first attempt at using the rotary axis on my machine. I wrote a file to produce a simple cylinder 3" x in diameter x 18" long out of a 3.5" square blank that is 24" long. I believe I have all the parameters set correctly within V Carve, but I'm not sure where to set the Z zero on the machine with the bit I'm using. Should I be setting it on one of the flat sides of my blank, or on one of the corners?
Also, where should I set the XY zero on my blank? It seems to me it should be on on the corner with the blank positioned flat, parallel to the table. I'm hoping to avoid snapping a bit on my first try...
2/2/18       #2: V Carve wrapping question ...
Try posting the questions on the V-carve forum on vectric.com. You will get a quick response.
2/2/18       #3: V Carve wrapping question ...
tom Member
Go to the Vectric site and look at the Aspire tutorial on rotary machining
2/3/18       #4: V Carve wrapping question ...
duster
Thanks guys, I think I found the info I needed. Also found some more on youtube.
