Weeke error !!
6/22/18
anthonyG Member
Hi all hope your doing great
i am having a problem with my cnc router a weeke vantage 38l 2009
can any one help me with that ??
View higher quality, full size image (1032 X 581)
6/23/18       #2: Weeke error !! ...
Dan
Don't have a Weeke but the last error mesage line may be a clue.
Check the sensor on the hood for movement and or build up of dust, etc.
It could need tightening and/or adjustment or may just possibly have enough dust contamination that it can't tell where it is.
6/24/18       #3: Weeke error !! ...
Chevy
Manually remove the tools from tool wiz, manually move the gantry by twisting the ball screw or physically pushing the gantry will clear that error,,,,
6/27/18       #4: Weeke error !! ...
anthonyG Member
Thank you all for your help its weird it use to work fine and now i am having this problem and i cant use my tool changer
View higher quality, full size image (1032 X 774)
5/3/19       #5: Weeke error !! ...
Jyrsija
Hey,
Check the wires that go on the tool carousel position sensors. See if they a tightly screwed on the sensor.
I had a similar problem with an older homag, was just a loose wire.
Also try what was said before this.
5/5/19       #6: Weeke error !! ...
Alexi
The tool changer needed to be leveled
Fixed
    • Machinery Associates
    • Country Saw and Knife
