DWG TO BIESSE
3/2/20
VALDUGA1 Member
HELLO, I AM IMPORTING A DWG FILE OF A LETTER TO BE "CUT".
WHEN IMPORTING TO BIESSEWORKS THE LETTER IS OUT OF THE MDP PLATE.
HOW TO MOVE THE IMPORTED FILE TO THE EDITING AREA?
3/2/20       #2: DWG TO BIESSE ...
Dan
I take it you are manually importing.
In the manual import section you should see both your geometry and the 'piece'.
Select the cut geometry, right click and select centre. You will have options for horizontal and vertical. Do both.
    • Country Saw & Knife
    • Palmetto Cabinet Doors
