Vertical Machining Centers
5/29/20
David Member
Does anyone who has hands-on experience with vertical machining centres (ie: Weeke BHX050, Biesse Skipper V13) know if they are capable of routing blind dado construction and grooves for pilasters or are they exclusive to dowel construction?
6/1/20       #3: Vertical Machining Centers ...
Rich  Member
We have a Biesse Eko 902. We do mainly dowel construction only issue with running dado's. If the part/dado is to long and the clamps need to re-position mid rout you will probably get a small misalignment where the two routs connect. If you do not do tall cabinets this might not be an issue.
The biggest gain we have with the vertical machine is being able to grip and machine narrow parts that would be an issue on our other pod and rail machines.
6/3/20       #4: Vertical Machining Centers ...
Michael
The Evolution from Holz-Her offers unique work holding by vacuum pods eliminating any interference on machining on the face as well as allowing full machining on all 4 sides, drill, router and automatic tool changer
link to video is below
If you are seeing this message, your version of flash needs to be upgraded to view this video.
Click here to get the latest version of the Flash player.
    • Biesse America
    • Template Services
    • Limtech Industries, Inc.
    • Palmetto Cabinet Doors
