Servo issues/alarms
6/1/20
RT Member
I have a new CNC that is giving me a Y axis servo alarm and is not able to cut a square edge due to encoder issues, my question is the machine is rated for 220v and is being run on 208 3-phase, could this be the culprit?
6/2/20       #2: Servo issues/alarms ...
Kirk
Most servos run on 24 volts dc. I would check voltage coming out of your 24v power supply and see what you get, and then check and see what your voltage is at the servo. If it's a new machine, it's not out of the question that you have a loose wire or a screw on a wire not tightened down enough.
It doesn't take much to interrupt that 24v dc as it travels throughout the controller.
6/3/20       #3: Servo issues/alarms ...
Jim Anderson
RT,
The difference between 208 and 220 is 12 volts which is a 5% variance and usually acceptable, It would help to tell us what kind of machine you have, but if the machine is not cutting square,you may have a physical misalignment causing the servo errors. Also what make are the servos and what is the error code/ message?
6/3/20       #4: Servo issues/alarms ...
Rob Young  Member
Could you provide more information? Is this a moving gantry machine? What brand and model? Do you have pictures of the parts? How did you determine it was an encoder issue? Are you getting any machine errors while the parts are running?
