Gemini Legacy CNC
5/28/21
Jon n Daniel Member
I am trying to help a small work worker who bought this machine. In five years he has had more than three spindle rebuilds. The main issue according to the rebuild house is tool unclamping while running as if the machine stop sensor does not give signal that's consistent. Currently the machine will not recognize that the spindle has a tool. I am told recalibration of the tool changer gets performed and it still does not know that a tool is present. Does anyone have any experience with this particular machine or manufacturer who can provide some insight?
photo_1.pdf
photo2.pdf
photo3.pdf
5/28/21       #2: Gemini Legacy CNC ...
All you need is a wiring diagram and lots of patience.
Start with the relevant switch/sensor on the spindle and work your way to the control. Somewhere there will be a break. If any wire looks iffy, replace it. Especially where the wire flexes.
Take apart and clean all connections. Remove and clean all grounds.
Take lots of pics.
That's the start. You can hire a tech but that's how they will start so do it yourself and save some $.
5/28/21       #3: Gemini Legacy CNC ...
cabinetmaker
Open the connectors at the spindle and look for a broken wire solder joint.
I had a very similar issue due to the repeated drop into the material and a connector coming loose, a 10 cent piece of solder fixed it.
Found it with a lot of patience and the electrical schematics
5/31/21       #4: Gemini Legacy CNC ...
Jim Anderson
Regarding the "activating while spinning", a bad or leaking air solenoid valve will allow small amount of air to push on the drawbar. I would also check to be sure the spindle dosent require air pressure on the release side to keep it clear of the drawbar.
RE: the tool not being recognized, possibly a bad sensor or sensor or drawbar out of alignment. If there are any LED indicators for the spindle, try watching them to see if the sensor is working but being past by.
6/1/21       #5: Gemini Legacy CNC ...
Jon n Daniel Member
Thanks guys for all the guidance! I will update when I get over to the machine and look at it.
    • Template Services
    • Better Vacuum Cups, Inc.
