Aftermarket dust skirt
8/28/21
BH Davis  Member
Thought I'd share this find.
I was looking for a better dust skirt for the CNC and found this on Amazon and Ebay. Being inexpensive I was skeptical but thought why not give it a try.
Well it turned out to be quite a good skirt. You have to order it for the size of your spindle nosing but that can be modified if yours is on the margin between two options. The different sizes all use the same main housing but come with different size bushing/fillers.
This skirt is attached directly to the spindle so would not work in an auto-retracting installation. However one side easily slides on and off for access to the bit for changes and height setup to the material
The brushes are fabric backed and easy to install. My only criticism is that I had some trouble finding replacements. As such I took the set that came with the second unit and cut those back to 1.5" long. That gives me a long and short set.
All in all I was so pleased with the skirt I bought a second one to have on the shelf should it be needed.
Dust skirt on Amazon
8/30/21       #2: Aftermarket dust skirt ...
Mark B
Do you run a tool changer? Interesting looking design concentrating the suction right around the spindle. Cheap enough.
8/30/21       #3: Aftermarket dust skirt ...
BH Davis  Member
Mark,
Yes, the concentration of the suction at the bit is exactly why I like this design.
I don't have a tool changer but if I do put one on the router it will have to be a vertical drop to grab the tool. Horizontally into a fork will not work with this dust skirt, at least without some serious modifications.
8/30/21       #4: Aftermarket dust skirt ...
BH Davis  Member
Hmmm....I think I'll take that last statement back. I should say it most likely won't work on most carousel and mechanically lifting types of tool arrangements.
It should work just fine on fixed location fork holders as long as they are spaced far enough apart and clear of surrounding obstructions that could be hit by the dust skirt assembly.
    • Biesse America
    • Template Services
    • Limtech Industries, Inc.
    • Palmetto Cabinet Doors
