I have that machine. The software is not bad.
A few things to note. I believe that machine has Allen Bradley controls. They are no longer supported and not generally available. So if something breaks you have to find it used which is becoming increasingly hard. Unique will update the controls for you for 100K +/-, how nice of them.
The hard drive gets corrupted over time. We have had issues several times.
Backup the software now. The backup contains all the foundational information not only on the tools that were in the machine but the machines set points and things like that.
What is the serial number? Is it Allen Bradley controls.
Check all the linear bearings, there are lots of them. Some are hard to get to and if they were not greased religiously they get sloppy or fail. Not impossible to replace buy a bit of expense and work.
That machine is 200K or more to replace. Jenkins makes a version of it .
That is not a fast production machine. It is good for fast redo's in a large shop. It is good for arched rails and panels. It would be fine but slowish for a small shop making doors.
Good luck!
