CNC trouble
5/21/22
Vadim Melnik Member
Hi my CNC keeps stepping up on the 2.5d carves? Any help is appreciated.
5/21/22       #2: CNC trouble ...
BH Davis  Member
If the up shift is gradual, then you have a Z-axis resolution issue. That's where the Z-axis is supposed to lift a specific amount but the machine is actually lifting a different distance. This should be adjustable in your initialization (or other control) file.
However if the up shift is sudden, as it appears to be in the video, you could have a loose or failing Z-axis drive mechanism. Check your Z-axis lead screw or rack and pinion mechanical connections.
5/25/22       #3: CNC trouble ...
Michael Member
Have you tried putting different sensors?
5/25/22       #4: CNC trouble ...
Erick Member
I'm not sure if the sensors are the problem. what is the power? could there be a bug in the program?
8/4/22       #5: CNC trouble ...
Rudolf  Member
Website: wattsan.com/
I think you have a loose or failing Z-axis drive mechanism
    • Better Vacuum Cups, Inc.
    • Template Services
