Cutting thick plywood
5/27/22
Erick Member
Tell me please, which cutter is best to cut plywood 30mm? you need to cut a lot and I can't find the perfect option, who cut what suggestions?
5/27/22       #2: Cutting thick plywood ...
Mark B
Just straight ply? No face veneer or laminate? That doesnt seem like a tough thing to nail down. What is your problem? Chatter? Cut quality? Speed?
5/27/22       #3: Cutting thick plywood ...
Tell us what size CNC you have. For a full size CNC, 30mm is no issue.
5/30/22       #4: Cutting thick plywood ...
Erick Member
Just straight ply, yes. Problem with cut quality and speed.
CNC machine characteristics :
Work area - 900 x 600 mm
Tube power - 80-90 W
Max engraving speed - 700 mm
Dimensions - 1030 mm * 1490 mm * 670 mm + 315 mm (if on its wheels)
Net Weight - 230kg
5/30/22       #5: Cutting thick plywood ...
No disrespect but that's not a commercial CNC.
What is tube power? Is this a laser?
What do you mean by 700mm? mm per minute?
Do you mean 3mm instead if 30mm?
5/31/22       #6: Cutting thick plywood ...
Erick Member
What does it mean not a commercial CNC?
80-90 W - Yes, it's laser power( power of laser tube).
right, per minute.
There is all characteristics about this machine. https://wattsan.com/product/wattsan-6090-st/
View higher quality, full size image (525 X 737)
5/31/22       #7: Cutting thick plywood ...
Sorry, I don't know about laser.
Only CNC routers.
5/31/22       #8: Cutting thick plywood ...
Calling something a CNC is not describing a particular machine. CNC means computer numerical control. That can be any machine with a controller and code, but it's obvious you are asking about a Laser Cutter/Engraver. This is not a forum with a lot of Laser Cutter discussion.
6/1/22       #9: Cutting thick plywood ...
My guess is this is a troll post to promote the machine manufacturer. Plonk.
6/1/22       #10: Cutting thick plywood ...
Mark
You might be right. Either way, for most of us on this site a laser is just a printer.
6/1/22       #11: Cutting thick plywood ...
There have been a couple of laser enquires, I assumed that English was not their first language, or they are a new hobbyist.
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
    • Biesse America
