Milling Compact Laminate
6/8/22
Dale K
Hi,
we are looking at milling compact laminate HPL,
What tooling is the go?
have been advised to use a diamond cutter with a thermal chuck.
Does anyone else have experience with 13-18mm compact laminate?
if so is it worth getting the diamond cutter?
6/17/22       #2: Milling Compact Laminate ...
Keelhauled
We do some toilet cubicle work in 13mm compact. We normally saw the panels on a beam saw as I'd need to break them down from 9x7 either way to fit on 8x4 flat bed. Then I use a 6mm PCD single straight flute for all CNC operations like lock fitting, hinge drilling and 10mm hole drilling as I need a perfectly clean drill hole both sides and unless the spoil board was freshly surfaced I'd get break out from the spur drill. I'd usually process the 13mm compact in 3 passes.
Regards
Mick
6/17/22       #3: Milling Compact Laminate ...
Keelhauled
I never had a need for a thermal chuck.
    • Better Vacuum Cups, Inc.
