Source for removable vinyl labels for Label-It software at CNC?
2/14/23
Matt Member
We've been using removable paper labels at our CNC for a while but everyone hates them. They are OK on prefinished plywood and melamine but when you put them on raw plywood or MDF, they leave a lot of residue that the finish booth has to remove with thinner.
We don't usually have to remove the labels but it's often enough (for various reasons) that it's becoming a problem.
Is anyone using a good vinyl (ie, won't shred) label that is also removable that you can suggest? What printer are you using?
Our current printer is a Zebra, it's great, and doesn't require a ribbon. I think most of the vinyl labels out there require a ribbon. Anyone find those a hassle?
2/24/23       #2: Source for removable vinyl labels f ...
anon1212
We started our labeling journey with paper labels on melamine 6 years ago and quickly transitioned to polypropylene labels.
They are much easier to peel and don't tear and in my opinion are well worth the small added cost over paper labels.
Our printers are all Zebra printers but you would need to verify that your printers support thermal transfer label printing. The process you're using now is direct thermal which is more expensive on average per label, but the machines are generally less expensive up front.
Loading in a ribbon for thermal transfer is very easy, and provides a superior more durable printed label than you would get from direct thermal. I wouldn't be worried at all about working with ribbons.
One thing of note is 95%+ of ribbon is a wax/resin combination which is great for most applications. We recently discovered full resin ribbon which is more expensive and prints a bit more slowly but the big advantage is the ink doesn't smudge at all. We used to very occasionally have issues with broken barcodes (due to rubbing when we stack parts on top of each other) which is a non-issue with full resin ribbon. With that said, if you are fine with direct thermal labels you would definitely be ok with the standard wax/resin ribbon.
We don't buy from them but ablelabel sells rolls of polypropylene labels in smaller quantities. https://www.ablelabel.com/polypropylene-labels/removable-adhesive-polypropylene-la
bels
For larger quantities I would recommend seeing if there's a more local supplier who can produce in larger quantities for you as there are often some nice savings.
2/25/23       #3: Source for removable vinyl labels f ...
Derrek
Abel Label makes a vinyl label that stick really good and doesn’t rip and peals off easily. Video below is about these labels and has contact info.
What is the best Label for labeling cabinet parts on CNC
https://youtu.be/hsxMO1BO-IY
Best cnc label
2/28/23       #4: Source for removable vinyl labels f ...
Matt Member
I actually have some labels from AbelLabel in my hands now.
I'm not sure they are cheaper, by my math these labels are about 4 cents each vs. the 1 cent I'm paying for paper labels. However, the quality difference is enormous.
I've got a message in to AbelLabelSystems about which printer I should be going with and what kind of life I'm getting out of the ribbons.
How many 4x8 sheets of cabinet material are you guys routing before you have to swap the printer ribbon?
2/28/23       #5: Source for removable vinyl labels f ...
Derrek
We label just about all parts. The difference between the paper and vinyl is the time to remove. The vinyl peels off without tearing and leaves no residue on the panel. The paper tears and sticks to panel and you need to use lawyer to remove residue. You can use the easy to remove paper, but they fall off to easy. You need a zebra printer that works with ribbon. They send ribbon with the labels when you purchase them.
