Drilling 2mm,4mm, 5mm
8/6/23
Andrew Prather Member
Website: http://www.joryworkshop.com
I am a old cabinet maker but a new CNC owner and trying to wrap my head around RPMs and plunge rates for 2mm, 4mm and 5mm drill bits into plywood and melamine. I have been looking hard online but I am not finding any manufactures specs or guidelines just chat room comments from hobbyist. Is there a website or calculator some where to look this stuff up?
We have a tool changer but not a boring head so I am trying to set up our drilling operation to be as efficient as possible. Most of the recommendations I am seeing are for a 5mm drill bit to be 6000 rpms with a 120ipm plunge. That said would it make sense I could do 18000 rpms at a 360 plunge rate or is that totally ridiculous? I recently nested some parts to make some shop carts and the boing operation was so sloooooww, after ripping through plywood with a compression bit a 650ipm. I also want to balance quality of the bore with efficiently. Thanks in advance!
8/6/23       #2: Drilling 2mm,4mm, 5mm ...
duster
I also have a cnc with an atc, but no drill bank. What I eventually arrived at through trial and error was a drill speed of 5000 rpm for my 5mm and 3mm drill bits, and a plunge rate of 1 inch per second. I get clean and a fairly quick row of holes with this feed & speed rate. It will never be quick as a drill bank, but it works fine for my lower volume operation.
8/6/23       #3: Drilling 2mm,4mm, 5mm ...
Dylan Bayliss  Member
most drill heads have an rpm range either fixed or variable in wood @ 4000~7000rpm. I would use 5000rpm (std rpm in most drill heads) and a plunge rate of 40in/min with program feed of 160in/min
That will produce a chipload of 0.016", assuming 2 flute drill, you can increase feed to increase chip and save tool life or increase rpm to ensure a cleaner hole, but sacrifice the bit.
Hope that helps, I attached a the FS Tool Chip Load chart and our guide to chip load with a calculator mid way down as well.
regards
db
www.cnc-tool.com
https://www.cnc-tool.com/technical-white-pages-chip-load.html
8/7/23       #4: Drilling 2mm,4mm, 5mm ...
Does your software have a pecking program for drilling? A 2mm drill will do so much better at keeping the flutes clear if you don't drill to depth in one cycle.
    • Machinery Associates
    • Country Saw and Knife
