Commercial Kiln Drying
End coating
2/8/17
Lou Henkel
Website: http://www.nemroc.com
Does it benefit to end coat green (80%+ MC) white oak lumber before putting it into the kiln? And if so can it be applied in below freezing temperatures?
2/16/17       #2: End coating ...
Bill Smith
Website: http://www.esf.edu/nekda
Yes, apply the end wax.
Unless end-trimming and stacking is absolutely, positively perfect some excessive air will blow past lumber ends and cause end checking. Value lost to end checking is very likely going to be a good bit higher than material cost and labor of applying wax.
I believe a winter formulation of anchorseal wax is available; call U*C Coatings to confirm.
