Dust Collection
Dust in your shop.
12/27/18
scott
I was wondering what kind of instrument do you use to test the air quality in your shop. My dust collector is a Dantherm S series and I was wondering if it is doing its job in an efficient manner?
12/29/18       #2: Dust in your shop. ...
Invite in an OSHA inspector, they are funded and not affected by the shutdown.
12/31/18       #3: Dust in your shop. ...
Unless you do no sanding and or use no hand tools you would not really be testing the dust collector.
A Dantherm does a nice job. Better than most. At some point you do have to replace the bags.
1/7/19       #4: Dust in your shop. ...
BH Davis  Member
This method is not precise science but you can use it to find out just how bad the air quality is in the shop.
Take a typical box fan and set it on a bench. Turn it on and then place a white pleated furnace filter over the back/intake side of the fan. You'll know soon enough if there is a lot of dust in the air as it discolors the white filter.
1/8/19       #5: Dust in your shop. ...
I like BH Davis idea, but machine and sand some padauk. You'll have a graphic visual example of the dust issues you have.
1/8/19       #6: Dust in your shop. ...
Kevin Jenness Member
Dylos makes some hand-held monitors . I borrowed one to see how well my central DC system picked up dust from my lathe and found it useful.
Dylos monitors
1/22/19       #7: Dust in your shop. ...
JR Rutter Member
Website: http://harmonicdesignworks.com
ditto on the Dylos. I bought one and it confirmed that the inadequate ventilation system of a commercial kitchen next to me was causing waaay more fine particulate pollution than my shop. The data was useful in getting the city to enforce building codes and get a proper hood system installed next door.
As for the Dantherm, I have an S-750 and it does just fine according to the Dylos.
7/3/19       #8: Dust in your shop. ...
Glenn
Website: http://www.aucklandcommercialcleaning.nz
So much depends on where and how much dust. We find mixing it up depending on the location and amount works well
