Dust Collection
Biesse
1/30/20
Looking for a electrical schematic for an older Polymac Lato 245 edgebander.
2/9/20       #2: Biesse ...
cabinetmaker
What’s the issue ?
2/9/20       #3: Biesse ...
Thought it might be easier to trace a circuit. This machine I just bought has pneumatic end trim beveling controlled from the plc. Dosent seem to be working unless there is a plc setting I am not using correctly. The plc just shows "Beveling" to turn on or off as far as I know.
May be a relay or solenoid Ill have to trace.
2/9/20       #4: Biesse ...
cabinetmaker
0 for off 1 for on
my old Lato 38 had Bevel end trimming that’s cutting front of the panel going through the bander vs the end of the panel cutting from 0 to 15 degrees, I think, but the bolts had to be loosened by hand then the plc applied air to the cylinders.
I was trained to unlock, turn the plc to 2 then let them move, and then retighten.
I don’t remember it being called beveling in the plc though
Interesting enough the seimens plc I had also had other options, although weren’t on the machine.
Here is an interesting thing and I hop it helps. My Lato 38 had two trimming stations for the panel. Meaning top and bottom trimmers. One was setup with straight cutters and the second was radiussed cutters.
I believe the plc turned the second set on and off calling it “bevel”. 0 off, 1 on.
Hope this helps
2/9/20       #5: Biesse ...
Thanks for the response. This machine refers to the second set of trimmers as rounders. They can be turned on or off and are working.
The term beveling is on the PLC. I assume that is what it refers to. The movement of the end trimmers by cylinders.
The end trimmers have a top cylinder that appears to be a clamping unit. Also, a horizontal cylinder that sets the location of the bevel. Only two locations can be set with the cylinder, thru a valve, opening or closing. This pivots the motor and blade. I was thinking I am not using the PLC correctly. Still may be a relay out. Not shifting the valve then cylinder.
    • American Fabric Filter Co.
    • GreCon
    • RT Machine Co.
    • Air Handling Systems
    • Denray Machine
