Dust Collection
Adding a mid-run drop
9/18/20
MB
I'd like to add a drop to my DC system in the middle of the main 7" run. It there any easy way to splice in a fitting without taking everything apart? Thanks.
9/18/20       #2: Adding a mid-run drop ...
Is it spiral or smooth? Smooth would be relatively simple.
9/18/20       #3: Adding a mid-run drop ...
MB
Smooth. How would you get it to engage on both ends?
9/18/20       #4: Adding a mid-run drop ...
John Costin
Use a saddle tap T like the one in the link or the equivalent from another manufacturer. No need to disassemble what you have -- just a drill a hole in the existing ductwork and pop rivet/caulk the fitting in place.
John Costin Veneer Services Unlimited vsu@gwi.net (207)459-7221 Custom Veneered Solutions for the Woodworking Industry
Saddle Tap T
9/18/20       #5: Adding a mid-run drop ...
For smooth I'd be in Jim's camp. Saddle or cutting in a takeoff if you dont have enough slack in the run to get a true Y in the line.
9/18/20       #6: Adding a mid-run drop ...
Sorry, John not Jim...
His link doesnt offer anyting for 7" but you can download saddle templates (or generate your own printed) to cut an angled takeoff in any diameter ductwork you need.
9/18/20       #7: Adding a mid-run drop ...
MB
Thanks guys. That's the deal. And now that I know what I'm looking for I see that Oneida sells one in 7" size.
Thanks for the help!
    • RT Machine Co.
    • Air Handling Systems
    • Sandman Products
    • American Fabric Filter Co.
    • Denray Machine
    • GreCon
